Order Farmall Cub Parts Online
Re: Clutch will not disengage ‘49 cub
old
06-14-2018 10:22:57
Disk in Backwards as John said. It will go in both ways but one way it will not release the other way it will.
Or if you force it to go together that will do it also. Seen more then one clutch disk bent by a person forcing things.
Don Hanvey
06-14-2018 11:07:16
 Re: Clutch will not disengage ‘49 cub in reply to old, 06-14-2018 10:22:57
Don’t recall forcing anything, “if it don’t fit don’t force it”
I did try to adjust the pressure plate fingers. Do u know the proper distance the fingers should be?
old
06-14-2018 11:19:45
 Re: Clutch will not disengage ‘49 cub in reply to Don Hanvey, 06-14-2018 11:07:16
Do you have the I-T manual IH-8. If you do the adjustment of the clutch is outlined in paragraph 190 page 50.
Don Hanvey
06-14-2018 13:20:03
 Re: Clutch will not disengage ‘49 cub in reply to old, 06-14-2018 11:19:45
I will see which manual I have, thanks.
glennster
06-14-2018 11:15:31
from the plate to the finger one and one eight to one and one quarter inches. plate, not splined hub.
Don Hanvey
06-14-2018 13:17:39
 Re: Clutch will not disengage ‘49 cub in reply to glennster, 06-14-2018 11:15:31
Ok, thanks
