Re: correct paint codes for farmall regular
Posted by Lyle on January 20, 2001 at 18:33:28 from (205.238.244.119):
In Reply to: correct paint codes for farmall regular posted by jeff fairchild on January 20, 2001 at 14:32:11:
The paint for a Regular is gray{Dupont 27625} and red for the wheels{Dupont 7410}You can use these numbers and any parts store can cross reference them to different paint manufacturers. I used these on my Regular and was very pleased with the outcome.
Post A Followup
: Re: Re: correct paint codes for farmall regular
Today's Featured Article - Engine Basics: Spark Plug Cleaning - by Staff. Cleaning procedures: Brush or blow dirt from around the spark plug base. Remove the plug with a correctly fitted wrench. Examine the porcelain insulator and points. If the insulator appears to be melted or blistered, cracked or broken, and the points seem unduly burned it is evident that the plug is operating too hot and it should be replaced with a colder plug. If the plug is fouled excessively with carbon it apparently is operating too cold and it should be replac ... [Read Article]
