Using a test lamp will depend on the voltage of your test lamp. You have to have continuity between wire and core & high voltage output terminal to core on secondary winding. Due to the high resistance of secondary your test lamp may not record continuity. An ohm meter will show near zero on primary (resistance is so low it will take a very sensitive ohm meter to give you a reading other than zero), and the secondary should be in the neighborhood of 7 thousand ohms.
Today's Featured Article - A Farmall Restoration Story - What's Been Done So Far - by Sean Brinston. This is a story of my first real tractor restoration. My name is Sean Brinston and I was 15 almost 16 at the time of this.My neighbour directly across the road who I had helped with hay all the time had this tractor sitiing at his house for what I thought was 6 years. Finally I got the money and courage to ask him. I phoned him and he said it was already sold, eight years ago!
... [Read Article]
Latest Ad:
1965 International Harvester McCormick Farmall cub tractor 2,500. Two owner tractor. My grandfather bought new in 1966, then we inherited it. Have all the paperwork original manual and all maintenance records. It starts and moves. Comes with underbelly mower, plough, and some other attachments.
[More Ads]
