Re: 5th Gear not working on M
Posted by D Slater on August 28, 2014 at 04:57:49 from (184.14.195.80):
In Reply to: 5th Gear not working on M posted by blohr on August 28, 2014 at 02:16:29:
third party image
third party image
Remove the belt pullet gear box or cover plate for the opening. Look at the condition of the internal teeth on the 4th and 5th sliding gear. Also condition of the external teeth on the rear of the input shaft pictured. Shake the shaft to get a idea about the bearings that support the shaft. Check for excessive movement or damage of the bearing on the front of transmission shaft that pilots into the input shaft. Check to see if the shift fork is moving the 4th and 5th slider far enough when in 5th. With tractor not running and no pressure on the gears see if you feel resistance of the shift lever when first moving it out of 5th. Internal teeth of gear near yellow numbers engages the teeth on rear of the shaft for 5th.
