govenor
Posted by momac on June 19, 2014 at 04:19:30 from (99.195.133.199):
My throttle lever requires a hard bump to make rpm changes. I've checked to make sure it's free to travel and found the input shaft on the governor is sticking. I've picked up another governor that works freely. Do I have to have the governor in any certain place to replace it. I know the drive gets timed to the cam and idler and all of that but to just R&R the governor is it needed? Thanks, Mike
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
