Re: Farmall h weak spark
Posted by El Toro on January 20, 2014 at 07:29:09 from (96.244.7.206):
In Reply to: Re: Farmall h weak spark posted by El Toro on January 19, 2014 at 08:41:18:
I told you the wrong way to wire your auto type coil if you decide to install one. If your battery is 6 volt and has the + terminal grounded your + terminal on the coil is wired to your points. Hal
Today's Featured Article - History of the Nuffield Tractor - by Anthony West. The Nuffield tractor story started in early 1945. The British government still reeling from the effects of the war on the economy, approached the Nuffield organization to see if they would design and build an "ALL NEW" British built wheeled tractor, suitable for both British and world farming. ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
