Posted by El Toro on January 19, 2014 at 08:41:18 from (96.244.7.206):
In Reply to: Farmall h weak spark posted by Brady miller on January 18, 2014 at 15:54:52:
Here's a picture of a H4 mag converted to a distributor. You use the points in the mag and disconnect the coil wire from mag's points. Battery voltage needs to be run to an ignition switch, to an auto type coil and to the points in the mag. If you're still using the 6 volt battery with positive ground you run the hot wire to + terminal on the coil and a wire from the neg terminal on the coil to your points. Hal
Today's Featured Article - History of the Nuffield Tractor - by Anthony West. The Nuffield tractor story started in early 1945. The British government still reeling from the effects of the war on the economy, approached the Nuffield organization to see if they would design and build an "ALL NEW" British built wheeled tractor, suitable for both British and world farming.
... [Read Article]
