Re: B acts like its running out of gas
Posted by old on November 30, 2013 at 15:36:28 from (209.86.226.60):
In Reply to: Re: B acts like its running out of gas posted by makin hay on November 30, 2013 at 13:36:43:
Over the main jet is a cap plug. Remove it and see if you get a good steady flow of gas. I'll bet you do not get a good steady flow out of it. I clean that main jet out by turning off the gas then with the drain plug out spray carb cleaner into it and with a torch tip cleaner tool I poke that jet out real good then spray carb cleaner in a again
Today's Featured Article - History of the Nuffield Tractor - by Anthony West. The Nuffield tractor story started in early 1945. The British government still reeling from the effects of the war on the economy, approached the Nuffield organization to see if they would design and build an "ALL NEW" British built wheeled tractor, suitable for both British and world farming. ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
