Re: B acts like its running out of gas
Posted by old on November 30, 2013 at 16:06:43 from (209.86.226.60):
In Reply to: Re: B acts like its running out of gas posted by makin hay on November 30, 2013 at 15:45:11:
Yes that is the one. Under it is the main jet and I'll bet it is clogged up. You should be able to pull that plug turn on the gas and have a good steady flow of gas out of it. If you do not then you found the problem. And as I said you can clean that out like I said and have a good chance you will fix it. BTDT on many old fixed main jet carbs
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
