Re: Mccormick 10-20 , sleeve piston help
Posted by 36F30 on September 18, 2013 at 19:16:50 from (174.30.67.98):
In Reply to: Mccormick 10-20 , sleeve piston help posted by kenny/md on September 17, 2013 at 21:29:24:
Alderson Tractor is has NEW sleeves for the 10-20/30 series.
He usually has good used ones too, plus anything else you will need. You have to call them about these sleeves, I don't think they are on the website. They will set you up, good people too.
http://www.aldersontractor.com/Home_Page.php
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
