Mccormick 10-20 , sleeve piston help
Posted by kenny/md on September 17, 2013 at 21:29:24 from (71.200.8.204):
I bought a 1936 10-20 ( not stuck) and got it home tonight and pulled the head off to go through the engine. Thought I was gonna be able to get away with a new set of ring, BUT, every cylinder has deep gouges- in line with the wrist pins. So my question is, does anyone carry new sleeve/piston assemblies for the 10-20. I"ve read that the F-30 sleeve and pistons are the same. Thanks for any help, Kenny
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
