Re: Re: Re: Re: F-20 running rough
Posted by T_Bone on November 26, 2000 at 09:42:52 from (207.254.52.170):
In Reply to: Re: Re: Re: F-20 running rough posted by Dick B on November 26, 2000 at 07:07:18:
Hi Dick, Your right as I forgot we were working on a F-20. I don't have a book on the F-20 so I can't give you spec's, but for some reason your point gap setting sounds wide. May not be as maybe I'm thinking of some else. I'd recheck your timing as I think thats where you having some problems and the back firing maybe here. Also your carb could be causing the backfire problem too. If it was me I would reclean the carb first just to make sure, then check timing, then recheck point gap. A leaking intake manifold will also cause backfire and you can squirt some oil around the gasket to see if this is the problem as it will quit when the oil fills the gasket void. Last on the list is the valves not opening correct causing backfiring, out of adjustment, bent push rod, stuck lifter, bad valves. Some of the above is generic to all gas engines so don't look for what you don't have. Just for refference the 1500rpm was a temperory setting for timing purpouses only. After the engine is timed correct then rpm is returned to normal. T_Bone
Home
| Forums
| Order Support
Today's Featured Article -
Product Review: Storm Covers - by Staff. We recently had a chance to try out the new Storm Cover for the Ford 9N, 2N and 8N tractor that is now being re-introduced to a new generation of Ford N-Series tractor owners. Originally produced more than 40 years ago, it is now enjoying a reproduction run that has been licensed by the Ford Motor Company. An original storm cover was used for the pattern, and this reproduction cover is indeed exactly as the original (of which we had previously only seen pictures of in miscellaneous old sale
... [Read Article]
Latest Ad:
Looking for a minneapolis moline zts
[More Ads]
Copyright © 1997-2026 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
