Re: IH 560 Shimmy
Posted by Heat Houser on July 03, 2013 at 08:58:11 from (69.66.35.73):
In Reply to: IH 560 Shimmy posted by slifnom on July 02, 2013 at 17:53:14:
Could be a number of things.
Pedestal bearings and others as mentioned.
Possible others.........
Lock nut on the top of the pedestal shaft loose
Disc that actuates the power steering valve loose
Splined U joint worn
Other U joints worn
Set screw loose that locates the worm into the power steering piston
Power steering rack/pinion teeth worn
Mine was the set screw. (your's may differ)Pulled the front bolster to remove the power steering piston to gain access to the set screw.
Today's Featured Article - Product Review: Electronic Ignition - by Staff. Oil, for example has come a long way in the last 50 years and I don't use anything but the latest API grade available. I've heard the arguments for non-detergent oils but would never trade it for today's formulations. Paint is another, the modern acrylic enamels are great for resistance to grease and fuel stains, retaining their shine and they last forever; unlike enamels and lacquers . Still another is the alternator. No doubt using the original generator keeps the tractor pure, but for thos ... [Read Article]
