when your coming up on the compression stroke , you line up the timing marks to the spec be it tdc or 2 degrees btdc. then you rotate the distributer opposite of the way it normally turns with a piece of paper between the points. as soon as you can remove the paper tighten dist down and you are statically timed. B is for before which is the same as A which is advance. got it now?
Today's Featured Article - Product Review: JB Weld - by Staff. JB Weld is basically an epoxy glue that does an exceptionally good job of bonding to cast iron and steel along with several other materials. As I mentioned, it is so common that I have yet to buy a tractor that did not have JB Weld used somewhere. It is sometimes used so well you can't tell its there and other times used as a sloppy quick fix. Finding where and how it can be used correctly is key to whether you are using it as an "inelegant hack" or an integral solution to difficult and expens
... [Read Article]
