'62 Farmall 560 Gas Timing
Posted by Pete D on April 23, 2013 at 14:37:11 from (71.7.50.219):
Hi all. Long story short, tractor was running ruff and was past due for a really good tune up. Cleaned and rebuilt carb, new coil, plugs and points. Where I made the big mistake was deciding to re-time the tractor. Now I"m pretty sure i"m out of time. Won"t start and I get backfire through the exhaust. I"ve read multiple posts on here dealing with timing and I"m STILL confused on one thing. My Timing marks go R-0,which also has a bevel there like it"s TDC.Then it goes to 10 20 30 40 -A.(with degree marks in between of course) First question is this : I"ve read many people using the thumb method to feel for compression and setting up as soon as the feel the compression. I was using a straw to see the cylinder come up. Am I letting it come up too far? Second question. And I know I should get it but I don"t. 2 degrees BTDC. Is that on the R or the A side of TDC. I read another post that said it was on the A side? When the engine turns it goes A first then degrees to TDC. So 2 degrees before TDC should be 2 degrees toward A so the engine fires before the cone lines up with TDC? Right now I have it 2 degrees toward A and I"m getting the backfire no start.
Thanks to all in A(dvance) =)
This post was edited by Pete D at 16:54:39 04/23/13 2 times.
