Re: Super A not charging
Posted by Janicholson on March 11, 2012 at 08:58:22 from (67.72.98.45):
In Reply to: Super A not charging posted by T Epp on March 11, 2012 at 08:21:35:
THe reason the amp meter probably doesn't move is that the output wire from the alt probably is connected directly to the battery. (through the starter switch) This works to charge, but does not run through the amp gauge. Trace the big wire and find its connection. It should be connected to the amp meter on the terminal not connected top the start switch. Other wires at that terminal attach to the ignition sw (if battery ignition) and the light switch. Test the new wires going to the alternator with it shut off, if any of them have enough current flowing through them (when disconnected and tested between their end and the terminal they attach to with a small light bulb, or more than about 50 ma with a ma meter, or 1.5 volts tested with a volt meter, the battery will drain down pretty rapidly. The original internal Voltage Regulator was modified by a company to excite with no wires connected to the spade connectors. If it does work now, it might be OK if it shuts off when the ignition is shut off, and it does not run down the battery. Jim
Today's Featured Article - A Farmall Restoration Story - What's Been Done So Far - by Sean Brinston. This is a story of my first real tractor restoration. My name is Sean Brinston and I was 15 almost 16 at the time of this.My neighbour directly across the road who I had helped with hay all the time had this tractor sitiing at his house for what I thought was 6 years. Finally I got the money and courage to ask him. I phoned him and he said it was already sold, eight years ago! ... [Read Article]
