Super A not charging
Posted by T Epp on March 11, 2012 at 08:21:35 from (66.222.110.226):
I have a Super A that was changed to 12v years ago and has stopped charging,voltage at alt. terminal reads 12v and drops as motor continues to run.It has the Delco single wire alternator on it. I removed the alternator to replace it with a 3 wire 10si and found it has a plug on the side with the 2 terminals like the 10si. I reinstalled it and connected the wires the same as a 10si,haven't installed the diode yet,and started the tractor. Now when checking the voltage both at the altenator and the battery I get 14.5 volts. When the conversion was done the amp meter was change to a 60 amp so I really don't see the meter move any I'm thinking since the battery is new this may be normal or the meter may be bad not sure. My question is has any one run across this before and is this going to be a lasting repair or should i just replace the alternator anyway?
Today's Featured Article - A Farmall Restoration Story - What's Been Done So Far - by Sean Brinston. This is a story of my first real tractor restoration. My name is Sean Brinston and I was 15 almost 16 at the time of this.My neighbour directly across the road who I had helped with hay all the time had this tractor sitiing at his house for what I thought was 6 years. Finally I got the money and courage to ask him. I phoned him and he said it was already sold, eight years ago! ... [Read Article]
