Re: H oil pump
Posted by Russ from MN on March 01, 2012 at 08:15:21 from (68.235.89.1):
In Reply to: H oil pump posted by Yooper Farmall on March 01, 2012 at 07:12:47:
I would think a shim would increase the pressure, especially when its cold. When the oil is hot it might leak past the worn parts so fast the pump can"t keep up, then you would see less that the relief set point.
