Posted by pete 23 on January 01, 2012 at 16:34:49 from (74.32.238.142):
In Reply to: 1066 Parking Brake posted by CWS650 on January 01, 2012 at 08:55:26:
It needs to have an over center action when engaged to hold properly. It is not necessarily worn out. If it is original type linkage it is no doubt bent and adjustment may or may not take care of it depending on how bent the link is. Reason they get bent is people force them trying to engage it. Pretty hard to explain on computer but I could easily show you if I was there. If they don't just pop in with a nudge you have to move tractor just a hair and the easiest way to do that is to let off brake and let it move or turn the steering wheel back and forth while tractor is standing still. That does not work of course if you are in a hole or place where tractor cannot easily move. A lot of tractors were converted to a spring loaded park which goes under the cover and then you can just put lever into park when tractor is stopped just like the 86 series.
Today's Featured Article - Horsepower Defined - by Staff. Indicated Horsepower This represents the power developed in the enine cylinder as obtained from the pressure in the cylinders. This is pressure obtained from an indicator which shows cylinder pressures. Indicated horsepower does not represent the actual useful power delivered by the engine. Brake Horsepower This is the actual horse power delivered by the engine to the shaft. It is equal to the "indicated horsepower" less the friction of the engine. It is useful hor
... [Read Article]
Latest Ad:
Late 50s early 60s international harvester 560 with cultivator
[More Ads]
