You have a bad O-ring between two valves or end plate or manifold. If you have three valves there will be four joints or 12 O-rings. IH part #: 350667R1.
I am surprised because it seems they seldom go bad. There are two more smaller O-rings on the splined lever shaft. There is a larger O-ring on the bottom cap. There is a gasket under the top cap.
Install 12 O-rings with the following measurements: 11/16"ID x 7/8"OD x 3/32"cross section and you will be leak free for now.
Today's Featured Article - Tractor Traction - by Chris Pratt. Our first bout with traction problems came when cultivatin with our Massey-Harris Pony. Up till then, this tractor had been running a corn grinder and pulling a trailer. It had new unfilled rear tires and no wheel weights. The garden was already sprouting when we hooked up the mid-mount shovel cultivators to the Pony. The seed bed was soft enough that the rear end would spin and slowly work its way to the downhill side of the gardens slight incline. From this, we learned our lesson sinc
... [Read Article]
Latest Ad:
[More Ads]
