Re: M/Super M Gear Shift Levers with single or double bends
Posted by Andrew Z on September 23, 2011 at 04:13:07 from (64.252.119.221):
In Reply to: Re: M/Super M Gear Shift Levers with single or double bends posted by D Slater on September 23, 2011 at 02:37:32:
Dave, do you think that some tractors got the bent shifter and some didnt? We have a 53 Super MD (Stage II) and a 54 Super H (Stage II) both with the unbent shifter. Only other thought was that maybe the replacement shifters were the unbent ones? Also both tactors came from the orginal owners and were pretty much untouched. Just some stuff to throw into the pot :)
Andrew
Today's Featured Article - Two-Brush Generators - by Chris Pratt. Whether for product liability or because the aftermarket parts and labor business is lucrative, this concept is disturbingly prevalent. Fortunately when you step into your shop and make that jump 50 years back in time to work with your old tractor, this concept goes out the window. Even so, when it comes to the charging system, people quickly revert to this idea and start replacing the major components one at a time until it works. The reason you don't find any decals in your replacement set wit ... [Read Article]
Latest Ad: WANTED IH C200 gas engine — complete running motor Wanted complete used IH C200 gas engine in running condition for an International 574 gas tractor. My block has a hole in it and is dead, so a rebuild kit wont do it — need a whole running motor. The C200 also came in the 544 and 674 gas trac [More Ads]
