Re: M/Super M Gear Shift Levers with single or double bends
Posted by D Slater on September 23, 2011 at 02:37:32 from (184.15.14.170):
In Reply to: M/Super M Gear Shift Levers with single or double bends posted by Eric Hartman on September 22, 2011 at 20:20:29:
On a SM the change from double bend shifter to single type bend was made when the battery box was moved to under the seat. It was one of the changes made to install the engine driven hydraulic liftall attachments. Changes to the tractor chassis were made on regular SM F-28175 or L-504802 and higher serial numbers. First built sometime in march of 53. Changes were made to the chassis after the serial numbers even if the tractor was still equiped with the transmisson driven hydraulics.
Shifter could be a replacement to the tractor and thats the type someone installed also. If just looking at the bends part of the M tractors used single bend ones. Also the H, SH.
On a M I think the double bend levers started showing up sometime in 1947. Have to look in my note book to double check.
This post was edited by D Slater at 03:04:58 09/23/11.
Today's Featured Article - Two-Brush Generators - by Chris Pratt. Whether for product liability or because the aftermarket parts and labor business is lucrative, this concept is disturbingly prevalent. Fortunately when you step into your shop and make that jump 50 years back in time to work with your old tractor, this concept goes out the window. Even so, when it comes to the charging system, people quickly revert to this idea and start replacing the major components one at a time until it works. The reason you don't find any decals in your replacement set wit ... [Read Article]
Latest Ad: WANTED IH C200 gas engine — complete running motor Wanted complete used IH C200 gas engine in running condition for an International 574 gas tractor. My block has a hole in it and is dead, so a rebuild kit wont do it — need a whole running motor. The C200 also came in the 544 and 674 gas trac [More Ads]
