Look for a 1/4 inch pipe plug on the left side near the front of the transmission case for the level plug. Fill from the top of the transmission near the gear shift, should be a 1 & 1/2 inch pipe plug with a 3/4 inch or so socket extension to remove. Do not fill the transmission above the level plug as the seals will leak and the brakes will not hold once they get soaked.
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and
... [Read Article]
