Posted by Farmall-H on January 10, 2011 at 17:18:51 from (74.36.102.99):
Is the transmission case lube and the final drive lubericant seperate? IF so, Is there a fill plug for the differential on the Farmall super A? cant seem to find one. Also, is there a fluid level check plug for the transmission case?
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and
... [Read Article]
