Re: Oil question
Posted by Red Dave on November 05, 2010 at 17:24:15 from (174.59.226.199):
In Reply to: Oil question posted by Dave Cook on November 05, 2010 at 16:23:54:
As was stated, 10w-30 or 15-40 will be just fine.
One suggestion though: If that tractor never ran detergent oil, I would take down the oil pan and scrape the sludge out of the bottom of it before running it on detergent oil. The detergent might break that sludge loose and get it in places that might plug up small oil passages.
Today's Featured Article - Engine Basics: Spark Plug Cleaning - by Staff. Cleaning procedures: Brush or blow dirt from around the spark plug base. Remove the plug with a correctly fitted wrench. Examine the porcelain insulator and points. If the insulator appears to be melted or blistered, cracked or broken, and the points seem unduly burned it is evident that the plug is operating too hot and it should be replaced with a colder plug. If the plug is fouled excessively with carbon it apparently is operating too cold and it should be replac ... [Read Article]
