Re: Hot Tanking
Posted by Roger46 on October 05, 2010 at 19:45:13 from (69.97.75.174):
In Reply to: Hot Tanking posted by PaulW_NJ on October 05, 2010 at 04:32:29:
I agree that you need to strip the engine down to the bare block for hot tanking. Then after hot tanking you need to make sure all the oil passages are clean. I usually try to run a brush down all the oil galleries and blow them out with compressed air. This means taking off all the plugs so you can clean all these passages. Dirt from hot tanking or dirt/grime soaked loose in these passages are bad for a newly overhauled engine bearings. I also recently had an engine block thermally cleaned where they heat it up to burn off all the crud. According to the shop where I had it done they said that you need to replace all the soft plugs, remove and replace cam bearings, and if the engine doesn't have sleeves you need to hone the cylinders as there is a residue that needs to be removed from the cylinders. Mine was a Farmall 350 diesel with dry sleeves, so I just needed to install new sleeves. Again, you still need to clean the oil passages. Roger
