Re: More help with fan hub.
Posted by David A.. Smith on August 26, 2010 at 16:12:44 from (72.70.197.134):
In Reply to: Re: More help with fan hub. posted by Theman on August 26, 2010 at 05:08:35:
I'm confused. I did get that pin out today and was able to remove the fan and pump drive. The fan is screwed to what looks like a threaded hub with some sort of large nipple on it. Behind that is another hub with a big set screw. Behind this is the pump belt and then the generator belt. Are you saying that the first hub (with the nipple) will screw off? And then the channel within which the pump belt sits is actually formed by two hubs - one forward (that I'm to remove) and one back which is pressed into the first? Boy! So remove the hub into which the fan was bolted (I do this by screwing it off). And tell me again ... what? Sorry to be stupid about this. I need help - I don't want to bust anything up beyond repair - but do want to get the cracked hub off. Again .. the cracked part is just behind the hub that had the fan on it.
Dave S.
Today's Featured Article - Magic Moments - by Tyler J. Woods. Magic moments don’t just happen. You have to help them along. This morning, I got up early. It is my day off from my regular workweek and I had a lot of things to do. It’s fall, and with winter coming on, there is a lot of work to do before weather closes in. ... [Read Article]
