Re: More help with fan hub.
Posted by Theman on August 26, 2010 at 05:08:35 from (65.198.133.254):
In Reply to: Re: More help with fan hub. posted by David A.. Smith on August 25, 2010 at 16:48:16:
Remove the locking set screw and jam nut on the cracked half of your water pump pulley and (carefully) turn the pulley half toward the fan blades. The threads are right-handed.
This movable half of the water pump pulley when turned forward will let the fan belt loosen enough to come off of the crankshaft pulley. That's why it is very important to clean the water pump hub threads and use spray lube before attempting to turn it.
Today's Featured Article - Magic Moments - by Tyler J. Woods. Magic moments don’t just happen. You have to help them along. This morning, I got up early. It is my day off from my regular workweek and I had a lot of things to do. It’s fall, and with winter coming on, there is a lot of work to do before weather closes in. ... [Read Article]
