Re: H STEERING SPINDEL BUSHINGS
Posted by LARRY LAURITZEN on April 16, 2010 at 05:38:16 from (69.19.14.24):
In Reply to: Re: H STEERING SPINDEL BUSHINGS posted by GordoSD on April 15, 2010 at 18:12:33:
This is a narrow front, top bushing under gear.
Thank you for your reply.
Larry L.
Today's Featured Article - Engine Basics: Spark Plug Cleaning - by Staff. Cleaning procedures: Brush or blow dirt from around the spark plug base. Remove the plug with a correctly fitted wrench. Examine the porcelain insulator and points. If the insulator appears to be melted or blistered, cracked or broken, and the points seem unduly burned it is evident that the plug is operating too hot and it should be replaced with a colder plug. If the plug is fouled excessively with carbon it apparently is operating too cold and it should be replac ... [Read Article]
