IH or Schwartz WFE? Tie rods in front or rear? I just replaced the lower bearing and bushings on an IH WFE on a SH. Die to elongation, corrosion and other wear I had to machine fit each part. Helluva long day.
Today's Featured Article - Engine Basics: Spark Plug Cleaning - by Staff. Cleaning procedures: Brush or blow dirt from around the spark plug base. Remove the plug with a correctly fitted wrench. Examine the porcelain insulator and points. If the insulator appears to be melted or blistered, cracked or broken, and the points seem unduly burned it is evident that the plug is operating too hot and it should be replaced with a colder plug. If the plug is fouled excessively with carbon it apparently is operating too cold and it should be replac
... [Read Article]
