Re: 706 squeaking rear end
Posted by Janicholson on February 17, 2010 at 13:37:32 from (199.17.6.222):
In Reply to: 706 squeaking rear end posted by ratnickwi on February 17, 2010 at 12:35:15:
Brownie has the answer I think. After checking the tightness with a wrench. Put a dab of fingernail polish on each rim clamp, and axle clamp at the axle. Let it dry, then drive it around squeeking. Look at the polish and where it is broken or crached it is loose.
Some bolts may need to be loosened then tightened to assure a true tightness. Using anti sieze on the threads can help. They must be tight. If it still squeeks, I would use a stethescope to listen to the axle. A 1/2" dowel will also work. to listen with. Be careful. Jim
