Re: Re: farmall-a freez plugs!
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Putt-Putt on April 16, 2000 at 14:49:26 from (12.6.95.208):
In Reply to: Re: farmall-a freez plugs! posted by p on April 16, 2000 at 13:44:08:
J.P, tell us what model. If it is a 123 engine like what is used on 100, Super A, C, Super C, you will need to break it apart (if the water is leaking from the bell housing) its likely you will find the freeze plug behind the clutch and flywheel needs replacing. Takes some effort but not impossible. If there is no water in your oil its likely a freeze plug. The design worked and hopely saved your block.
Post A Followup
: Re: Re: Re: farmall-a freez plugs!
Today's Featured Article - Two-Brush Generators - by Chris Pratt. Whether for product liability or because the aftermarket parts and labor business is lucrative, this concept is disturbingly prevalent. Fortunately when you step into your shop and make that jump 50 years back in time to work with your old tractor, this concept goes out the window. Even so, when it comes to the charging system, people quickly revert to this idea and start replacing the major components one at a time until it works. The reason you don't find any decals in your replacement set wit ... [Read Article]
Latest Ad: Massey Ferguson model 65 diesel tractor [More Ads]
