Forgot to answer part of the question...
Posted by Bob on May 21, 2009 at 09:27:56 from (69.178.228.68):
In Reply to: Re: can't kill f-4 magneto posted by Bob on May 21, 2009 at 09:18:56:
""I took my vom meter to check continuity between the body of the mag and the points.I tried all different combinations to put the probes between.I get continuity everywhere no breaks.What next?""
You WILL get a low-resistance reading at all positions 'cause the coil's primary winding is an almost dead short to ground, very low Ohms.
Simply put, when the the points are closed or the advance lever is in the "kill" position, there is even less resistance to ground, ZERO Ohms, which places a short across the points to ground, "killing" the spark.
Today's Featured Article - More Memories of a Field Service Engineer - by Brian Dye. Introduction: The author worked for one of the largest Ford tractor dealerships in England as a trouble-shooter on tractor engines, hydraulics and combine harvesters from 1963 to 1972. In 1972 he became a dealer manager and finally left the dealer net in 1975 to run his own electronic design and manufacturing company. [Editor] We live right in the middle of Norfolk. The dealership that I worked for sold Fordson Tractors from the 1920's and some of t ... [Read Article]
