Posted by Bob M on May 12, 2009 at 08:23:20 from (151.190.254.108):
In Reply to: In-Line Fuse posted by Johnny Lawson on May 12, 2009 at 05:10:54:
Good advice below from John T. Expanding just a bit:
1 - DON'T use a fuse in the alternator output circuit (alternator BAT to ammeter to battery + post). Reason: Should the fuse ever let go while the alternator is charging it'll likely ruin the alternator.
Note that OEM manufacturers typically do not fuse this circuit for this reason (also for cost...)
2 - For your 39 amp alternator use a minimum of #10 wire for the circuit above (#8 is preferred.)
3 - Assuming only normal electrical loads on your H (ie. just lights and ignition using #14 wire) use a 20 amp fuse where the lights/ignition switches get power - ie. at the the ammeter post wired to the alternator. This will locate the fuse conveniently in the ammeter box - just like the tractor was wired orginally.
Today's Featured Article - Grain Threshing in the Early 40's - by Jerry D. Coleman. How many of you can sit there and say that you have plowed with a mule? Well I would say not many, but maybe a few. This story is about the day my Grandfather Brown (true name) decided along with my parents to purchase a new Ford tractor. It wasn't really new except to us. The year was about 1967 and my father found a good used Ford 601 tractor to use on the farm instead of "Bob", our old mule. Now my grandfather had had this mule since the mid 40's and he was getting some age on him. S
... [Read Article]
Latest Ad:
1965 International Harvester McCormick Farmall cub tractor 2,500. Two owner tractor. My grandfather bought new in 1966, then we inherited it. Have all the paperwork original manual and all maintenance records. It starts and moves. Comes with underbelly mower, plough, and some other attachments.
[More Ads]
