Re: 806 wont start
Posted by caterpillar guy on January 17, 2009 at 06:52:37 from (64.12.116.73):
In Reply to: 806 wont start posted by kansasmike on January 16, 2009 at 23:39:17:
Like MN Red said or the low pressure pump might be out. Check the return line can you blow air through it? If it is plugged will not run as to much pressure in pump. Is the throttle pulled open some. I start ours with the throttle wide open then as it starts move it back to an idle to prevent running wide open cold. Change the fuel filters if not done already.
