Re: Char-lynn Power steering on M from MD
Posted by Marv on December 19, 2008 at 14:43:22 from (75.105.128.37):
In Reply to: Char-lynn Power steering on M from MD posted by Chet R. on December 19, 2008 at 13:18:42:
Chet, Yes it will work but with some modifications. In went from a gas SM to a SMD...just opposite what you are doing.
You will need to get a guage mounting bracket for a SM. The guage brackets are different, mainly because of the bracket that is needed to hold the throttle lever. I don't know about the bracket or pump from the MD. For sure the bracket is different. A good source of information and parts would be Force America located in Humbolt, Iowa. Telephone 800 362 2994 and ask for Derrick in the shop. I did not use the belt driven Char-Lynn pump on the SMD. Instead I used the existing distributor driven hydraulic pump. I installed a flow control and plumbed it so the Charr-Lynn orbitor motor would not be overloaded.
I would be willing trade the guage brackets (the one you need for the one off the MD) if you are interested. Marv 319 835 5685
Today's Featured Article - Talk of the Town: Removin Broken Bolts - by Staff. Another great discussion from the Tool Talk Discussion Forum. The discussion started out with the following post: " How would I remove a bolt thats broken off in a piece of metal and I want to save the treads in the metal and then put in a new bolt. " ... [Read Article]
