Char-lynn Power steering on M from MD
Posted by Chet R. on December 19, 2008 at 13:18:42 from (64.7.166.10):
I am looking at buying a Char-Lynn power steering system from a MD. Will this work and bolt on my gas engine SM the same way as the diesel or do I need to get mounting brackets for a gas engine. I guess my question is I know the setup from a gas M will not work on a MD because of injection pump and other items that are in the way but will the MD setup work on a gas M. Thank you for any help you and give me.
Today's Featured Article - Horsepower Defined - by Staff. Indicated Horsepower This represents the power developed in the enine cylinder as obtained from the pressure in the cylinders. This is pressure obtained from an indicator which shows cylinder pressures. Indicated horsepower does not represent the actual useful power delivered by the engine. Brake Horsepower This is the actual horse power delivered by the engine to the shaft. It is equal to the "indicated horsepower" less the friction of the engine. It is useful hor ... [Read Article]
