Re: Napa coils didn't work! M Farmall
Posted by James Rumph on November 19, 2008 at 03:40:36 from (24.192.125.175):
In Reply to: Napa coils didn't work! M Farmall posted by Dave Hollrah on November 18, 2008 at 20:19:52:
All "tractor" coils in reguards to our older I.H ones have a resister built into them.
Meaning:
If you use a automotive coil you will be useing a external balast resister to do the same thing.
You can use a auto coil with out it but the coil will get hot .
So like Hugh said stick with the correct parts and you won"t have a problem.
I use a M.S.D coil and brain box on my pulling tractor [12 volt] and it uses a external balast resister.
Maybe your coils are fine and you need to look at the ign. switch [ power on/off].
All the power on that tractor goes threw that switch lights, gauges, starter etc.
I had a problem like yours with the tractor, it turned out that switch was bad.
It must be replaced with a high amp one , the little 15 -20 amp switchs don"t cut it. I ended up installing a 50 or 60 amp one and zero problems.
Today's Featured Article - A Farmall Restoration Story - What's Been Done So Far - by Sean Brinston. This is a story of my first real tractor restoration. My name is Sean Brinston and I was 15 almost 16 at the time of this.My neighbour directly across the road who I had helped with hay all the time had this tractor sitiing at his house for what I thought was 6 years. Finally I got the money and courage to ask him. I phoned him and he said it was already sold, eight years ago! ... [Read Article]
