Re: 1940 B clutch chatter
Posted by Janicholson on October 21, 2008 at 20:15:20 from (66.173.50.160):
In Reply to: 1940 B clutch chatter posted by Scott-Tx on October 21, 2008 at 19:38:49:
Probable throwout bearing. It is a split to fix. It will be important to replace the P Plate, friction disk, and pilot bearing as well. Check the splines on the input shaft, and dress any burrs found on them, or replace it if worn/rough. Face the flywheel and make sure the step of the PP mout surface stays in spec. JimN
Today's Featured Article - Antique Tractor Wiring Basics - by Curtis von Fange. One of the most neglected parts of old tractors is the wiring. After sitting in the elements for half a century or more much equipment wiring has deteriorated to sparsely covered strands of copper or other metal. Plastic insulation has cracked, mice have eaten through the older clothed style coverings and the exposed wires have reacted to winter moisture and salts by turning blue and powdery. Terminal ends have corroded, rusted or just plain evaporated away. Aged wires not only keep an engin ... [Read Article]
Latest Ad: 1952John Deere MT tractor [More Ads]
