Re: advice for splitting super a
Posted by Hugh MacKay on September 02, 2008 at 14:17:58 from (209.226.106.77):
In Reply to: advice for splitting super a posted by Mark W. on September 02, 2008 at 10:13:29:
Mark: The first thing you should do is make a couple of wooden wedges to drive in between axle and steering box. The way I do it is place a hardwood pallet under front end, then block up to two points at each end of axle. Then make a large U to fit under oil pan, in such a way cast is taking weight not the oil pan, and block under that. Tie the entire front end down to pallet with rachet straps. Place a bottle jack under clutch housing and a pallet jack in pallet.
Then it's just a matter disconnecting all plumbing, wiring, etc. between the two halves. Then unbvolt the clutch housing and roll the front half away on the pallet jack.
Make sure you install a new pilot bushing, a new release bearing, a new pressure plate and new clutch disc. Don't put the clutch disc in backwards. I did it once in a hurry, so have dozens of other YTers. Another thing to check is make sure clutch pedal linkage to release bearing is not bent.
I've done 6 now got it down to a 5 hour job by myself. It wasn't the first one that I put the clutch disc in backwards. Watch that one closely, especially if you have friends around that like to examine things and put them down, opposite side up.
Today's Featured Article - Talk of the Town: Modern Diesel Fuel in an Old Tractor - by Staff. This interestin discussion is from the Tractor Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
