Re: Farmall 140 Sickle Mower
Posted by Hugh MacKay on June 04, 2008 at 08:56:26 from (209.226.106.137):
In Reply to: Farmall 140 Sickle Mower posted by rdragoo on June 04, 2008 at 08:11:13:
rdradoo: There were two belly mount sickle bar mowers available for SA, 100, 130 and 140. A-22 was the farm mower available in only 5" or 6" cut models. There was also an A-23 roadside mower, and it was 7" cut. Quite heavy for these little tractors. One had to install the cast wheel on the left to use it.
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
