The closed end of the hydraulic assist cylinder has something that looks like a spool from a typical hydraulic valve. It is buried inside and not visible. The ball on the end of the pitman arm moves the spool and directs the flow.
Very simple and probably rebuildable with o-rings. Never had mine apart.
The steering valve in the steering cylinder is open center. All you need is a flow control valve w/safety, reservoir, any pump, and misc hoses.
If you are going with IH, make sure the flow control valve is 364 841 R93. It has an internal transverse regulating spool on the lower sides of the valve casting.
If I were in your shoes, I would go to a salvage yard and get the right parts including the pump. Everything is mounted out in the open and easy to get to. It should be cheaper than making up alot of hoses and buying an aftermarket FCV. The IH valve will be pancaked onto one or two implement control valves. Get the whole thing.
Today's Featured Article - Grain Threshing in the Early 40's - by Jerry D. Coleman. How many of you can sit there and say that you have plowed with a mule? Well I would say not many, but maybe a few. This story is about the day my Grandfather Brown (true name) decided along with my parents to purchase a new Ford tractor. It wasn't really new except to us. The year was about 1967 and my father found a good used Ford 601 tractor to use on the farm instead of "Bob", our old mule. Now my grandfather had had this mule since the mid 40's and he was getting some age on him. S
... [Read Article]
Latest Ad:
1965 International Harvester McCormick Farmall cub tractor 2,500. Two owner tractor. My grandfather bought new in 1966, then we inherited it. Have all the paperwork original manual and all maintenance records. It starts and moves. Comes with underbelly mower, plough, and some other attachments.
[More Ads]
