Re: IH Powersteering Question
Posted by IH2444 on April 30, 2008 at 13:22:36 from (192.76.82.90):
In Reply to: Re: IH Powersteering Question posted by Ron in Nebr on April 30, 2008 at 10:49:15:
On Hydrostatic steering there is no physical mechanical shaft attachment. I think the hand pump puts pressure on a proportional valve assy as you turn it (connected by hoses) and causes the proprotional hydraulic ram controller to move the hydraulic rams accordingly. The proportional flow divider is to tap into the main hydraulics and drop the pressure down to 600 lbs for the flow that goes to the hydrostatic steering if I remember correctly for the steering system.
I will look thru my manual tonight.
