Re: Engine number and serial number
Posted by Hugh MacKay on April 22, 2008 at 19:53:12 from (209.226.247.127):
In Reply to: Engine number and serial number posted by Mudshot on April 22, 2008 at 19:36:31:
Mudshot: To start with 251089 R1 is not the engine serial number, it is a part number. IN IH any number ending in Rx or Rxx is a part number. Furthermore 251089 R1 is not a part number used at factory as original engine for any of these tractors. It must be a replacement engine, or you've read it wrong.
251069 R1 would be the engine block part number for early Super A. Does it have factory hydraulics? If it is a Super A the engine and tractor serial number do not match. Engine serial numbers are below no. one plug, but on a machined flat surface and the numbers are stamped as opposed to cast in place. The digits are only about 1/4 inch high.
Today's Featured Article - History of the Nuffield Tractor: Conclusion - by Anthony West. In the last piece I mentioned that Nuffield had reached the stage where they had chosen to drop the "Universal" from production. The two new models were given three figure numbers, instead of "three" and "four". Model numbers were introduced to help farmers and dealers instantly recognize the engine size and horsepower of the tractor, the 4/60 had a four cylinder diesel engine which developed 60 bhp at 2,000 rpm. The 3/42 had a 3 cylinder diesel engine which produced 42 bhp at 2,000 rpm. Th ... [Read Article]
Latest Ad: 1952John Deere MT tractor [More Ads]
