Re: Engine number and serial number
Posted by Andy Motteberg on April 22, 2008 at 19:43:13 from (4.143.222.156):
In Reply to: Engine number and serial number posted by Mudshot on April 22, 2008 at 19:36:31:
The number you are looking at, 251089R1, is NOT the serial number, that is the engine block part number. There should be a flat spot on the block that has the serial number stamped in it. You can also get your year by searching the tractor for casting codes, the letter at the end of the code is the year. (Example: 4-22-M would mean April, 22, 1943).
Here is the year for each casting letter:
1939 - I
1940 - J
1941 - K
1942 - L
1943 - M
1944 - N
1945 - O
1946 - P
1947 - Q
1948 - R
1949 - S
1950 - T
1951 - W
1952 - X
1953 - Y
1954 - Z
Hope this helps!
Today's Featured Article - History of the Nuffield Tractor: Conclusion - by Anthony West. In the last piece I mentioned that Nuffield had reached the stage where they had chosen to drop the "Universal" from production. The two new models were given three figure numbers, instead of "three" and "four". Model numbers were introduced to help farmers and dealers instantly recognize the engine size and horsepower of the tractor, the 4/60 had a four cylinder diesel engine which developed 60 bhp at 2,000 rpm. The 3/42 had a 3 cylinder diesel engine which produced 42 bhp at 2,000 rpm. Th ... [Read Article]
Latest Ad: 1952John Deere MT tractor [More Ads]
