1941 farmall m clutch adjustment
Posted by Frank in Texas on February 13, 2008 at 19:00:19 from (209.55.76.12):
I recently purchased the tractor and am very pleased with it. I noticed the clutch has very little travel when releaseing it. Previous owner stated that it may need an internal adjustment thru the plate underneth. I attempted to adjust the outer rod but wow what a mistake. I had to put it to its original setting. I did manage to get to go into gear while the engine is running/ Previous owner stated you had to shut off the tractor in order to change gears with out grinding them. Any help in this area would be appreciated. Thanks
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: John Deere 750 Diesel Yanmar J80TU engine. pistons and rings replaced when discovered crankshaft was bent. 3995 OBO Pictures available upon request [More Ads]
