Posted by CityBoy-McCoy on December 18, 2007 at 05:54:55 from (209.214.106.31):
In Reply to: Rough running H posted by Mark in NC on December 17, 2007 at 19:20:26:
Mark: And also, as I have just learned, if you have a battery type ignition, it could be your distributor needs a rebuild. Remove the cap and rotor. Then see if the shaft can be wiggled side to side, like a loose tooth. If so, your points won't stay set while running and it will run rough much of the time. mike
Today's Featured Article - Upgrading an Oliver Super 55 Electrical System - by Dennis Hawkins. My old Oliver Super 55 has been just sitting and rusting for several years now. I really hate to see a good tractor being treated that way, but not being able to start it without a 30 minute point filing ritual every time contributed to its demise. If it would just start when I turn the key, then I would use it more often. In addition to a bad case of old age, most of the tractor's original electrical system was simply too unreliable to keep. The main focus of this page is to show how I upgr
... [Read Article]
Latest Ad:
1965 International Harvester McCormick Farmall cub tractor 2,500. Two owner tractor. My grandfather bought new in 1966, then we inherited it. Have all the paperwork original manual and all maintenance records. It starts and moves. Comes with underbelly mower, plough, and some other attachments.
[More Ads]
