Re: Charging System
Posted by GooseCreek Farms on August 21, 2007 at 15:10:04 from (64.12.116.73):
In Reply to: Re: Charging System posted by John T on August 20, 2007 at 06:51:28:
Got a chance to work on the backhoe today and the first thing I did was to switch wires on the ammeter and it did show discharge when I turned the key on. I then started the backhoe and got it to charge by grounding the "F" terminal on the VR to the tractor. Also noticed that one of the contacts on the VR closed when I did this. However, my hand held voltage meter only showed 13.7 up from around 12.4 when it wasn't charging. I still don't know my what problem is ... wiring or VR? Any suggestions?? Another thing I noticed was that the generator was quite HOT to the touch. Is this normal?? I appreciate everybody's help so far and would once again welcome any suggestions to fix my problem.
