Posted by El Toro on August 20, 2007 at 06:36:24 from (64.12.116.73):
In Reply to: Charging System posted by GooseCreek Farms on August 20, 2007 at 05:56:45:
Check the charging voltage at the battery with a volt meter and see what your voltage is with the engine at 1/2 to 3/4 throttle. Make sure all your wire connections are clean and tight. You may need to have your local shop check your regulator and generator on their test stand. You should be getting around 14.5 volts at the battery. Hal
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and
... [Read Article]
