Re: Charging a battery backwards
Posted by Owen Aaland on July 06, 2007 at 19:08:27 from (65.165.246.40):
In Reply to: Charging a battery backwards posted by marvin johnson on July 06, 2007 at 10:37:39:
Part of the trick to getting the battery recharged properly without futher damage is to make sure it is completely discharged before recharging correctly. Keep a load on the battery until the voltage stays near zero when the load is removed. Trying to recharge it without completely draining the voltage can lead to excessively high tempertures in the battery which will ruin the battery.
